944Scott
Did you have any issues fitting the kit? I bought a set with slim ballasts and a separate control box which only uses one of the original bulb connectors as a feed and I cannot get it to work correctly. Any combination of bulb and ballast on either end of the separate control unit works fine but as soon as you hook both sides up one will not work.
The supplier sent me a replacement loom/control unit but I am still having the same issues.
