Forte Oil Flush & Brake Pads
944psi
Planning to "recommission" my S2 so have a list of jobs to complete.
For the oil & filter change is an oil flush worth doing? It has a clicky tappet on start up so normally stick in some hydraulic lifter treatment after the change but pondering whether to run a flush first.
One of the other jobs is to replace discs, pads and calipers all round. Was thinking to go for basic Pagid pads? Normal car - probably won't see a track so thinking stick with basics.
Phil
Have to say , I know you meant 'standard' or suspect that's what you meant but I wouldn't call Pagid pads basic , more like excellent. :)
Best of luck with the to flush or not to flush issue. My vote is yes .
Regards. Mas
As has already been said, forte oil flush is worth doing and 'standard' pads will do you just fine. I find these people to be very cheap for pads and disks;
http://brakeparts.co.uk/
