Front anti-roll bar bushes
- Thread starter Guest
AirCooledExcellence
I did mine last year. The worst bit is replacing the roll bar after you've installed the new bushes.
Apparently some cars require the removal of the A-Arm, but I managed to 'spring' mine back into position. Just make sure you use plenty of lube in the bushes and that the ends of the sway-bar that push through the A-arm mounts are smooth and free of rust.
Good Luck!
Tim.
