Front Brake Caliper Bolts -What thread and size?
Hi All
Anybody have 2 of the these for a 1982 Porsche 924 for sale? I require 2 or does anybody know the thread size?
Steve
The parts CD shows bolts part numbered N 010 137 1 described as Hex Head M12 x 1.5 x 35 - could that be what you need?.
That sounds about right - the thread is Metric Fine rather than the usual. You should also check whether they should be grade 8.8, 10.9 or 12.9 as this application is what you might call safety critical. If you can look at the other caliper bolt heads you should be able to make out the grade markings.
