Hi All
Some basic questions from a fairly new owner.
I need to remove the brake pads and calipers. What is the best way of releasing the shaped spring that holds the pads in the caliper.
Also when removing the caliper is it best to release the brake hose from the bracket on the strut by removing the clips that holds it there. Otherwise it looks like you would bend the brake pipe which is not a good idea.
Thanks Phil
Thanks Phil
