smallspeed
Im currently in discussions with a major pad manufacturer, having purchased a set of their pads which didn't fit my calipers.. My previous pads were OEM and seemed to have been fitted without any modifications to the backplates, however the new "upgrade" pads I purchased are too wide across the backplate to fit. I checked the spring clips when I took the old pads out and they are well seated, and made sure the whole caliper was clear of pad dust and fully cleaned up.
While I managed to fit the new pads (they were a bit tight going in but not much worse than the old ones coming out) as soon as I applied the brake they bound on and wouldnt let go. This resulted in me spending about 4hrs releasing the calipers and removing the pads (which were masacred in the process). I've since replaced these with pads from a different source which fitted and work perfectly
Has anyone else had experience with pads not fitting in the front calipers? I spoke to my specialist who said he knew people filed down the back plates of some makes of pad to make them fit, however the pad manufacturer say there's no way people do that with theirs as there's no need. Having taken some measurements of pads and calipers they now say the pad back plates are wider than the caliper opening..
Any peoples experiences gratefully received; Im not looking for a mud slinging contest, hence no names mentioned, however I would like to find out if this is a general problem or a freak one off..
Thanks in advance
Ben
Thanks in advance
Ben
