zwhitea
Just in the process of replacing the brakes on all four cornings... however I've come up against a silly problem with the fronts...
Is there a knack in removing the dust cover on the hub, so that I can remove the hub, disc and backing plate....?
And here I was thinking the caliper fixing bolts were going to be the issue...
Thanks in advance...
