In order to get my headlight washers working, I had to remove the driving/side lights from the front bumper of my 1984 944. The screws were horribly corroded with the result that they had to be drilled or cut, while some of the tabs in the panel were already snapped off. I would like to replace the whole panel - are they available new anywhere? I suspect that ones from breakers will be just as bad as mine.
Front bumper
- Thread starter gothatway
Bow Runner
I need to buy a replacement for one on mine. I'll be interested to know the price at an OPC.
jonn
Is the ABS Plastic bumper you are after ? if yes then I have a new one bought for my 85 lux but never used as the body-shop repaired the old one ( I think because it was easier than replacing)ORIGINAL: gothatway In order to get my headlight washers working, I had to remove the driving/side lights from the front bumper of my 1984 944. The screws were horribly corroded with the result that they had to be drilled or cut, while some of the tabs in the panel were already snapped off. I would like to replace the whole panel - are they available new anywhere? I suspect that ones from breakers will be just as bad as mine.
