Hi,
I am looking for some advice on replacing the front brake discs/pads. I have read the "technical article" within the 996 forum area, but when looking at my Caliper I see a different view to that photographed in the technical article (for the boxter).
I have a 2003 996 carrera 4. At the rear of the caliper are 2 bolts holding a bracket. This bracket holds the interface between solid brake line and flexible brake line, plus 2 electical connectors.
I am assuming I need to remove both bolts to the bracket and remove both the electrical connections in order to get enough flexibility/movement to remove the caliper out of the way (to replace the discs)? If so do the electrical connectors just pull off (as there seems to be another smaller bracket holding them on)?
Thanks, Jason
Thanks, Jason
