ORIGINAL: Tim court
Bob,
Have dome this to three GT3's now, including my own. It doesn't need to be a two man job.
There is a good DIY on Rennlist for the third radiator install which goes through the easy steps for removal of a boxster PU which is identical..
The basics are....
1. Put the front up on axle stands.
2. Open the luggage lid and remove the black plastic cover around the latch. Use a big bladed screwdriver and turn the buttons 90 degrees to release.
3. Remove the 2 philips screws and cups underneath that secure the PU.
4. Remove the buttons that secure the front section of the wheel arch liners. BTW, taking the wheels off helps access but is not essential.
5. Crawl under the car and remove the row of philips screws and buttons securing the bottom edge of the PU.
6. Pop out the indicators by pulling the rear edge outwards and then sliding them rearwards.Remove the exposed screw underneath. You will also see the pointy end of another screw on the bottom edge.
7. Removing the bottom PU screws will have slackened off the wheel arch liner so tug it loose so you can get your hand and a screwdriver inside the PU, under the indicator position and feel for the last screw.
8. Put a dustsheet or similar on the ground and ease the PU forward. you will have to spread the sides a bit to get around the indicator moulding.
9. Make a cup of tea and inspect the wildlife in your rads.
10. After you have ftted your mesh using small tie wraps and a few discreetly drilled holes replacement is a reverse of the above. Before you tighten everything don't forget your temp sensor. It is fiddly to get back in.
11. It is easier to cut and fit the mesh by removing the rubber rad ducts and try the fit rather than trial using the whole PU.
12. If you do decide to clean between the rads, which is a good idea just be careful you don't damage the aircon condensors as they are quite delicate.
Good Luck.
