KWv3 is a brilliant option. I bought a set of s/h KWv3 and got a free 944 S2 with it [
] It's not quite stiff enough for serious trackday use IMO - I fitted stiffer springs to mine, similar to their clubsport spec, but is a great road / track compromise. (btw I'm still running std S2 ARB's but the car handles so nicely that i don't want to change anything at the moment)
I was so impressed the first time I drove a KW car - just at gentle road speeds. It felt so much more modern somehow. This was compared with Leda dampers on my car, which were in turn better than m030. Build quality is pretty good, and there's no corrosion on the shock bodies to worry about so they will look great for years.
Damper adjustment is easy on the fronts, but the rears have to be removed to get at the top adjuster (can't remember if this in bump or rebound). I tend to leave mine alone. Support from KW UK and Germany is very good.
Depending on the ride height you want, you may not need to get torsion bars re-indexed. It will depend on the adjustment you have available on your spring plates. Mine was fitted without needing re-indexing. Obviously this can add a fair bit to the fitting costs, and also the "while you're in there" jobs - I'm just having my rear axle re-bushed & it's probably costing the best part of £1k in parts for new bushes & mounts!
I wouldn't discount Bilstein though, great products and would be my #1 for a road S2 now - maybe together with 968 m030 ARB's (not cheap) to help address body roll on track.
