Front Undertray
- Thread starter jodypress
Brett928S2
I dont think anyone does a plastic one as its to protect things like your aircon compressor from grounding....
I dont have one on mine and never have, I did think about it but the ally ones are around £400 and for an S2 like mine you also need an extra front section....and if you have never had one you will also need all the bolts and fittings....
All the best Brett
sawood12
I can't imagine what possible benefit an aluminium one would give you over the original standard part, so i'd save your money. It might offer you better protection from light grounding as Brett suggests, but even then a thin sheet of aluminium is not going to offer much protection if you were to ground with enough force to cause significant damage.
