chrisg
Morning All !
Whilst fitting some new brake pads last week, it became apparent that the front O/S wheel bearing had some play in it. Further investigation/inspection is it isnt too bad but has some wear (may be able to tighten up/ shim). However, for the sake of ~ £40 for new bearings, races & grease seal I'm thinking I should do the job properly.
Clarks give a fairly good job description, before I dive in and try their method, has anyone tried it before or got experience of:
1. Removing the grease seal
2. Tapping out the races and installing new ones
3. Refitting
thanks
Chris
3. Refitting
thanks
Chris
