I'm getting a 'humming' noise from the front wheel after about 20mins of driving, it goes when light braking is applied or if steering slightly turned, only to return again after 5 mins or so. Noise is not always constant but usually occures at some point during a run....any thoughts ?
Front Wheel Noise
- Thread starter head3275
Def a front caliper binding
Mine does it too []
The caliper is designed to retract slightly into the caliper when you lift off the brake pedal to give a running clearance between the pad and the disc and after 20 years, one of mine is not quite pulling back.
Needs a caliper strip down, clean of the pistion and the bore plus new seals as they have probably gone a bit harder with age.
Mine does it too []
