Front wipers
DavidL
My wipers are getting progressively noisy and its a very annoying scream. Everything works properly just not quietly!
There seems to be nothing on Clarks so is there likely to be an obvious solution?
If it isn't the blades then I agree with Rich. I'm not sure what you mean by the linkage being involved, but it's fairly simple. There are 2 pivots where the spindles poke through the scuttle, one each end of the 2 (replaceable) linkage arms (though as they are nylon cups I doubt they will be squeaking) and the motor output spindle. As I recall that's it for moving parts
