I need help. I have a 2005 plate Boxster. I work shifts and the car is my daily drive. Every winter the windows freeze up and won't drop when I try to open the car. I can carefully open the door without the widow droping, and it's possible to close the door again, but only from the outside, because I have to easy the glass into the hood recess. When I lift the door handle, I can hear a clunk clunk clunk noise as the mechanism tries to drop the window, but it's all frozen solid, even with a slight frost, and the internal lights diminphase with the clunking sound. Even whenI open the door, the widow will not drop using the door switches until the car has warmed up. This is really useful at 5 am!
My local OPC denies it happens and appears disinterested. I find it hard to believe that a can designed for German winters can suffer from a problem like this! Any advice would be much apreciated.
KP
KP
