Fuchs Alloy Offsets - as follows:
Very simply, the offset of a wheel is the distance from the body face (fixing point to the hub) to the centre line of the wheel rim.
Wheels are produced in 2 basic parts, the centre body and the rim - both are then positively fixed together at differing points within the rim width. There are three alternatives : positive, neutral and negative offsets - ie, where the rim is pushed outward and away from the hub, that is a negative offset and vice versa for the positive offset. A neutral offset is where the hub face and centre line of the rim are on the same line.
Rim width is the only variation on wheel size - ie, an 8" rim will have less of a negative offset than a 7" for the rear of a 911.
The 15" and 16" Fuchs Alloys as fitted to the 3.2 Carrera come with pre-set negative offsets for the three rim widths of 6", 7" and 8" - as follows :
6 J x 15 H2 - 36,0 mm
7 J x 15 H2 - 23,3 mm
8 J x 15 H2 - 10,6 mm
6 J x 16 H2 - 36,0 mm
7 J x 16 H2 - 23,3 mm
8 J x 16 H2 - 10,6 mm
Offsets have a direct impact on the car's track dimensions - which increase or decrease accordingly as the track is measured from the centre line of the wheel/tyre. To increase the track, you will run a negative offset OR alternatively, run spacers between the hub face and the wheel body - thus moving the entire wheel outwards and increasing the track and effectively the offset from the hub face (not wheel body).
In a nutshell then, offsets are quite important to the overall geometry of a suspension set-up and are designed by the manufacturers to work with the basic principals of the car design and handling.
FYI : I am running a 'piece' on the Fuchs Alloy history in May PPost.
