Fuel cap cable broken
- Thread starter Beaky
I don't think you will find it difficult to open your filler cap. You can see the catch if you look into the gap.
You can push the catch (the lower one) towards the front of the car using something which won't scratch your paintwork, possibly a wooden lolly stick?
Brian.
Jacob
Buy some string or strimmer wire.
cut about a 12 inches off.
Hold the string/wire with one hand at either end. Line the middle of the string/wire to the top (nearest the windscreen) of the fuel filler cap and gently run it under the fuel filler cap trying to catch the hook that the wire would normally pull.
good luck
As for the original cable looks like the end locating/locked item just came off, so poked the wire through again and used a nut & bolt to secure, works OK
