Fuel consumption and sticking rear brakes?
oldtimer
Hi , I'm new to 997S (3.8 engine) ownership, second owner of a 9000 mile car , but noticed that with my everyday non aggressive driving I get about 22mpg , whereas the 996tip (3.4 engine) it replaced did 26mpg driven same way. Is this normal ?
Second point I've noticed is that if left undriven for a few days , the brakes appear to glue up , so there is a distinct and noisy resistance to moving off for the first time . Looking at all 4 disks , 3 of 4 are smooth , but one of the rears is grooved. Before I traipse back to OPC , thought I'd check the forum . Any ideas?
My 13,000 miler is exactly the same. I normally only get it out at weekends this time of year and the brakes make a noticeable crack when reversing out of the garage, worse if put away when damp/wet etc. It takes a good few stops for the brakes to scrub in and warm up before starting to perform. I posted almost the same query when I picked mine up 2 months ago!!
As for the grooving, it depends how bad it is but my rears don't look particularily pretty, unlike the fronts which are fairly smooth - so, probably no real problem?
And the consumption seems a good match for what I can return, although it does get better if I use it for commuting on the M5, rather than just the Sunday thrash around!
Thanks for the reinforcement !
I actually jacked the car up wheel by wheel to rotate them , and seemed OK ie brakes not obviously sticking . I used the jack from my other Porsche as I didn't get one with the 997 !
The best fuel consumption I get on a motorway is 29 mpg, and not a problem as the biggest cost of ownership will be depreciation as my 996 proved. Its worth it though , and the 997S is a great car .
John
22 is about right - mine has been up to 28 on 'a run' but averages between 21 - 23 mpg.
Graham
My 997s manual has averaged 19.5mpg over 8,000 miles, without much town driving to drag the average down.
If you're averaging over 20mpg, you're not trying hard enough [:D][:D]
ORIGINAL: pvernham
so so true !!!
I get 25.2 mpg on the motorways / long distance and 14.2 when I'm feeling a little playful.
Revised figure! Just done a bit of track day at Oulton and achived 12 mpg! Must try harder next time and get down to single figures!
GPM
Well my current average is around 24mpg, and my wife managed 29.5mpg on a trip down to Bognor yesterday.
To be fair, the car has only done 310miles and is still being run in so I do have a good excuse.
I promise to get down into the 'teens once the running-in period is complete !!
Sidicks
Interested to hear that you've ventured onto the track with it Graham., thought you were worried about stone chips...[:D]
How did the brakes/tyres stand up to it ? I gave a 997S driver a ride(untimed) round Donington in the 964RS at last years PCGB trackday , and he then gave me a ride round in his 997S , with the chrono and PASM on. Interesting back to back comparison . The 964RS felt faster but it was hard work ! Maybe when I get used to driving the 997S fast ,as others here are suggesting , I'll go back to Donny in it , Oultons bit too narrow for me [;)]
ORIGINAL: oldtimer
May help if you leave the handbrake off and just leave the car in gear if leaving it for a few days (obviously only if the car won't roll off etc) as this will prevent the handbrake pads binding to the disk.
It was so wet on Friday that I doubt I suffered to much tyre wear - the brakes and PASM etc worked wonders. Ran on Sport Setting and had a fantastic time. No evidence of collecting stone chips as I each time I caught cars up the marshalls 'Blue Flagged' them out of my way[:D]. Even Neil in his 993TT couldn't stay with me[;)] - maybe I just left my sensible head at home on Friday[&:]
GPM
I'm pretty sure when I posted on this subject in January, someone indicated that the handbrake doesn't act directly on the rear disks but inboard of the wheels, perhaps on an output shaft?
I haven't a clue if this is correct, but I still leave the car in neutral and with the handbrake off (luckily my garage floor is dead flat!) to stop it all binding up.
Thanks for the info, nsm3.
FWIW , I never put the handbrake on when I park up at home anyway as I am aware of how it can fuse itself to the brake surface.
This month I left the car for 8 days and when I came to use it , it needed an almighty shove on the accelerator to break the 'stiction' and get it moving...then got some grinding noises for first few applications of footbrake . I don't think the latter is unusual as the 996 used to do same. Will discuss with OPC .
