Fuel economy gauge flickering?
The Fuel economy gauge has started flickering, It still works but seems ultra sensative now.
Any ideas or where its pickup wiring block is located so I can check the connection etc...
Is there some confusion here, the fuel guage works off the fuel sender, The economy guage is a vacuum guage so I would imagine it has a sender on the inlet manifold, or a vacuum pipe down to the ecu like the turbo boost guage - except it goes to the klr box which an na car doesnt have.
Tony
Not knowing if it was electric or mechanical was the reason I didn't post anything. If it's flickering that would suggest it's electric I guess. I've never had a 944 with one so I have no idea how they work really.
Figure is calculated by injector duration against speed, so not a traditional vacuum gauge.
It's run electronically by the DME so check the 3 multiway conectors that conect to the back of instrument panel. Maybe a 'wiggle' will cure it.
HTH
Rick.
ORIGINAL: 944Turbo
thanks Rick, everydays a schoolday :)
So true. I thought it was a vacuum gauge as well. But as Rick has one on Baby Wuf (and knows about such things) he must know what he is talking about.
ORIGINAL: 944Turbo
Tony
Quite right Tony, I must pay more attention[&:]
