Fuel Filler Door Central Locking Solenoid
hobdayd
Hi,
Can anyone tell me how to remove the plastic liner inside the fuel filler door without damaging it? I need to have a look at the central locking solenoid...it has stopped working recently.
Thanks,
Don
Hi
Don't know what model you have but on my 955 I could access the solenoid from inside the boot next to the CD changer. Mine had just stuck and needed WD40 from the outside and a wiggle from the inside then all fixed
Graham
Access is different on the 958. The access hatch in the boot is small and not near the solenoid. The plastic liner under the fuel filler flap has to be removed. I have only found a couple of links on the internet...both show the plastic liner being damaged in the process and a £1.00 plastic moulded part is £143.00 from Porsche.
