Fuel filter
- Thread starter KS2
Tool Pants
non Club member but v. knowledgable
Even before then it was 60,000 miles and I doubt you have that.
bryno
The filter should be located under the car below the seats, you have to remove a large plastic underside protector to get at it. Loosen the filler cap, remove the protector, undo an earth wire, have something to catch any fuel drips.
To undo the fuel lines from the filter squeze the retaining collars on either side (these are on the filter body where the pipes go in and out of the filter) Undo the filter retainig strap and pull the filter backwards. When replacing make sure you get the direction right, replacment is the reverse procedure, replace the earth strap and check for leaks befor putting the protector back, close the filler cap.
Let me know how you get on.
Bryn Owen
Technical Assistant
Boxster Register
