ChasR
My fuel gauge is playing funny buggers on me. Sometimes it goes up to around halfway (with around £30-40 of fuel in it) and sort of bounces a little at that level and then it will tail off to almost hitting the bottom.
Today I went into the boot and took apart the awkward sound deadening around the fuel tank, and checked the resistance at the G and T terminals via Clark's guide at the sender. This showed around what I expected it to be. With bouncing the car around slightly, it moved slightly in accordance too.
However, when I put a 4 Ohm resistor to sender terminals on the wiring with the ignition on the sensor hit the bottom line, and as soon as I took it off, the sender went down to to the bottom.
My dad then took a look at reference voltages. At terminals G and T I think (I'll need to ask him) it only produced around 2.1 Volts when he thought it should be 5V. He then tried it via an earth on the car and it went to 8.6 volts.
I have taken the cluster out before and given the multiplug connections a clean with cotton buds, Super 10 switch cleaner and then some application of Vaseline (ooo err). I am suspecting that it is either a gauge fault, stabiliser fault or a ground fault.
Where is the ground for the sender and also where is the stabiliser and what voltage should be present at it.
It may be worth mentioning that the temp gage had a habit of going schitzo (maxing out) with the tapping of the clock sometimes bringing it down. Whilst it's not gone, it has much improved and it is much more stable as a result.
So where should I look next?
I should point out that the warning lights (parking brake, ABS etc.) Oil pressure and voltage all work fine as do the tachometer and speedometer.
