Guys,
I'm hoping one of you good folk can help? Before I set off on a recent trip to Spa I filled the car up with fuel (not something often done). The fuel gauge went to full as normal.
After about 200 miles the gauge had dropped to 3/4 of a tank and stuck in that position. After a number of refills it stayed on 3/4 of a tank.
On the way home it stopped working completely and read empty.
When I got home I removed the sender unit which was in a sorry old state and binned it. Yesterday I collected and fitted a new sender unit from Porsche. When I started the car the gauge showed 3/4 of a tank. Suspicious I went to the garage and put £20 of fuel in. Starting the car again, no difference still 3/4 of a tank. A side note, the oil level gauge is showing full and hasn't budged in quite some time.
Has anyone any idea what's causing the problem?
Thanks in anticipation of your support... Paul
