Fuel Leak At Croft yesterday I noticed that my car started leaking fuel out of the filler cap ( I think) even though the tank was only half full.I have never had this problem before and the strange thing is it only seemed to happen on one bend, the second right hander after the start finish straight (sorry cant remember the name) on the rest of the lap it didn't happen. Does any one have any ideas on why this should happen? Any help would be appreciated. ThanksNick
Fuel Leak
- Thread starter Nickp
PIRATEPETE
Nickp
Yes this happened to me. It is a known problem. There is a flap (in effect a valve) inside the neck of the filler this wears out and stays open. When you corner reasonably hard the fuel surges out of the vent inside of the filler flap. Paul from gt classics did mine under warranty (no fuss) so i have no idea of costs apart from a vague recolection of £100 parts mentioned.
Once filler neck replaced no further problems. My technical knowledge of this may be slightly dodgy but it is the filler neck any specialist will be able to advise on correct pats needed.
Hope this helps
Hope this helps
I had a similar problem that seemed to be cured by replacing the filler cap. I just swapped mine out to see if it cured it and it did. I used my Boxster one to test it. My guess was it was the rubber seal on the filler cap had perished.
Stewart H
Sounds like you may need to replace the filler neck - Part No. 964.201.043.06 £98.70 + VAT
Replaced mine back in April - so the price was right then, don't know if there have been any increases since. This part is an improved part from the original one and has a more secure joint to the body.
Church
Had exactly the same issue as 'rs phil' on track. Tried different fuel levels and new filler cap to no avail.
New filler neck solved the problem. I think the angle a fuel pump sits in the neck whilst re-filling can cause it to become deformed over time esp if you lean on the pump whilst re-filling.
ok got filler,took only 10 mins to fit,when fitting new one lube up the rubber grommet before pushing through towards flap, i used some tyre gel,found the problem with the oe one,when you blow through either pipe it blows straight out at cap end,with the new one this doesnt happen it seals so fuel cant get out,but if you take your thumb off one pipe and blow it bypass through each pipe...this will defo sort the problem...hope this doesnt confuse[]
