Fuel line connections on Fuel distributor
Gibbo
hi, I'm changing my air box(kabooooom), so had to removed the fuel lines from the distributor, marked on top of the banjo nuts where each line went in permanent ink(clever), cleaned it up using petrol and washed off the markings(not so clever), can any one confirm where each injector line goes on the fuel distributor, I have trawled the wonder web and diddley sqwat... cheers
As each injector "fires" constantly with no timing relating to individual cylinders,it probably doesn't matter-that is if it's the same system as on a 924 with fuel flow dictated by the lifting plate in the inlet tract.
