John Maddox
944T let me down while in the lake district when the fuel pressure regulator on the fuel rail failed. Symptom was running rich with lack of power on boost and a little black smoke from exhaust, then total failure and engine wouldn't run. RAC trailered it home.
Here is the important bit - fitted new regulator and it felt 50 hp up on how it always felt before. It is now very significantly faster than before. Only cost £32 +vat direct from Bosch (Half that of OPC).
If you think your 944T is not as quick as it should be this is worth replacing.
