Got home this morning at 4am from the Classic, car running like a pig!! It all started on the trip up from Le mans. She went great over the weekend and after running round the parts of the track available on the Sunday night with only a 1/4 of a tank of fuel left I filled up for the trip home (some french filling station, can't remember the name), so set off for Dunkerque and within an hour she started popping and farting and refusing to rev past 3000 revs, once we stopped for a break I spoke to the lads I was travelling with who had the same fuel and they seemed ok, so we started off again and for 20 mins she was ok then it started again, pops and bangs from the exhaust and a refusal to rev so at this point I'm thinking it must be that fuel!
So we arrived at the port and then she refused to start! Couldn't hear the fuel pump on turning the key so checked the fuses and the fuel pump fuse was badly positioned and was burnt (as if it had been arcing), changed the fuse and she started great, got on the ferry happy as larry convinced I had sorted the problem, obviously the fuel pump had been cutting on and off!!
Once back in blighty it started again and gradually got worse, checked fuse which is now fine. Filled up with some BP as it was all we could find at the time (I usually use shell V power) and it got to the point where I could run for about 30 - 50 miles as the power got less and less before pulling over, resting her for 5 mins and then off again, so its now had a full tank of BP through the system and still doing it. She starts no problem, idles as normal but doesn't sound as smooth but won't rev past the 3 and pops and bangs still!!
Is it possible that the incident with the fuse has damaged the fuel pump?
Any ideas lads?![. [FONT=verdana,geneva"] [FONT=verdana,geneva"]](/forum/styles/default/pcgb/space.gif)
Any ideas lads?
