as a newbie to these great cars im doing a resto on a y plate 82 2.0 everything is going well up till i decided to change the noisey fuel pump ,i took the fuel lines off top and bottom and connected them on the top one i used the original pump nozzle and union and fresh seal then to the wiring i had to cut the wires which on the old pump was 2 black and green wires on the smallest terminal and 2 brown on the largest and placed them on and secured them the same way and discovered the brown wire from the in tank pump was broken off but the car still ran? so i reconnected this it was the upper terminal,so then i went to try and start it and all it would do was turn over and not fire with an occasional cough, can anyone help with the wiring side-have i wired correctly or suggest where i went wrong
thanks graeme
thanks graeme
