Fuel tank valve????
jetbox
Hi,
Car went to the garage today and the diagnostics found a faulty fuel tank valve??? Can not remeber the fault code though. They have ordered the part and I need to book in to get it replaced.
What does it do? what happens when it goes wrong??
thanks
Jetbox
It is probably the tank venting valve/evaporative canister purge valve. If it fails, it makes the mixture slightly rich or lean, depending if it fails open or closed. This would give a fault code, but wouldn't trigger the Check Engine light (on a UK car).
It could, as it is a solenoid valve. Item 5:
thanks richard.
I took the car back to opc for l/h radiator resistor and tapping noise from the left bank. The resistor is on order and they say the vent valve is causing the noise... Need to book the car in again to have these parts fitted under warranty. Will let you know if they cure the problem
many thanks
ORIGINAL: jetbox
.......and tapping noise from the left bank. ....... and they say the vent valve is causing the noise....
Maybe I'm confused here, and there are two issues, but I doubt very much if the vent valve would cause a tapping noise from the left bank. It is located right at the top of the engine, and solenoids make a buzzing sound when they play up, not a tapping sound.
I have to agree with you, I dont think its this valve but I'll get this fixed and see....
well, the garage changed both fan resistors and the fuel vent valve... Success so far as the tapping noise appears to have stopped so far...
Garage also enabled OBC at the same time so now have the outside temp display on the dash too.
well pleased...............
