full wheel alignment where ?
davepaul993
hi, how often is it advisable to have full wheel alignment ?
where near east grinstead (sussex) is there a place that can do it ?
has anyone in sussex had it done ?
I think they really need a full suspension geometry check/adjustment anually. I certainly notice mine being a bit off after about 9 or 10 months.
Can't help with a suitable place though as I'm at the other end of the country.
i use GT-One in Chertsey (M25 jnc 11) - a very well respected firm.
More locally, i think, you have Paragon - not sure what they are like for this kind of work, though they sell plenty of 993s
A little far unless you fancy a run, but Camtune in Godalming can do the full set-up, including kinematic toe (whatever that is!). They did an excellent job with mine, although I must admit I don;t do it annually. A little expensive for that!
Cheers/John
I've been to both Camtune and GT One for 4 wheel alignment. Recommend either. Definitely made a difference, even though it was only very slightly out. GT One do a real thorough inspection while your car is up, I was amazed at the detail they went in to. Would go back to either one again, for alignment and service too. Good luck
i had a full geometry check and re-alignment at jz machtech (kings langley) and it cost me about £150, no complaints although wouldnt get it done annually unless you know you've done something to knock it out.
Tognola, Datchet near Windsor are also good and are recommended by numerous people. Had mine done there and I noticed a definate improvement in handling and more even tyre wear since.
Andy B
