Fumes in cabin
- Thread starter sbloxxy
edh
If it's the lights, you'll probably also be able to see water leaks into the car when you clean it.
The rear lights have a black sealant that sounds like it needs replacing - the light clusters should come out reasonably easily if the seal is that poor. You can buy a roll of the sealant from your OPC for a few quid
random hero
I get the smell of fuel in the car though.
I have had the exhaust changed, Bought a New tailgate seal, sealed up around the sender unit with mastic and it still stinks!! None of the pipes are leaking as I also changed The Fuel pump. Out of ideas now!!!
Indi9xx
Then crack the window open just an inch or so, and again note the fume level.
If its worse with the window closed, its probably being drawn in through the engine bay through a gromet or the blower assembly
If its worse with the window cracked open an inch or so, its probably the tailgate seals, rear light seals, or a bung or gromet missing at the rear of the car.
Another thing to check for... if the number plate is stuck on with number plate tape rather than screws. If so, check to make sure the screw holes are plugged up, otherwise they will draw in exhaust fumes.
The problem with 944's, is that they develop a low pressure area around the back of the car, which exhaust fumes can lingure in, even at high speeds (which is why the back of a 944 with a rich mixture turns black).. so if you have a leak back there and crack open the window a little or open the sun roof, you oddly enough cause an even lower pressure area in the cabin, which then draws the exhaust fumes through any leaks at the back of the car.
