FUSE / RELAY BOARD CHANGE
SECTOR
Hi all.
I have a 1983 944, the fuse / relay board is located under the dashboard, passenger side. It is in need of replacement due to lots of bad
connections etc., has anyone changed theirs, if so with what and where from.
Thanks all
You can still buy them from Porsche. You may also find that it is the same as a MK1 golf. The last time I changed one it cost £90 new from Porsche ( cheaper than VW at the time ). Its an easy job to do. Just take your time and swap the plugs on the back over one at a time.
