G50 Gearbox
Hi Pagey,
Anything can be done, but this is definitely not a straighforward swap! $$$$$$
You'd have to change all the gear linkages, shifter, pedal cluster etc...
If you've got a warn out 915 you'd be better off paying to have that re-built, they shift just as good (some say better) that a G50 box when fresh!
Good luck,
Tim.
I'll third that on cost but experimentation helps us all. Make sure the exchange box has a very good warranty.
You also need to cut out and weld in the G50 torsion bar tubes to make room for the physically larger G50.
Think cubic dollars.
Richard
ORIGINAL: paggnr
How easy (or can you) retro fit a G50 Gearbox to a 1978 911SC?
cheers from Oz
Pagey
G50 can easily be put into reverse gear when selecting 1st [:mad:] Never had that problem with my
915's
get the box you have rebuilt, better then an exchange as it keeps it original and the box has a number on it.. i have seen in 911 & porsche world a company (i think may be in USA) selling a short g50box, not sure but i think its if you want to fit one in a 915 car as the torsion bube would not have to be messed with.
steve
ORIGINAL: paggnr
cheers from Oz
Pagey
Pagey, must have seemed like a good idea at the time!! [:D]
Mel
Having driven just that (i.e. a well sorted 915) not so long ago, I was very impressed with the ease of the 915. I'm in need of a new 1st to 2nd synchro - baulky when cold - under these conditions, I can often pass unfavourable comment whilst trying to rush the change.
You can't.
Good advice to re-build that 915.
