gear box oil/ transmission oil
- Thread starter jac997
The SC Porsche manual specifies Hypoid gear oil SAE 90 GL-5. You need 3 liters. I use Miller oils. The one for the SC is part code 7929 Classic motor oil EP90 GL5. This is for a standard gearbox. I assume you do not run an LSD. There is a different oil for this setup.
Standard gearbox oil:
![www.millersoils.co.uk](https://www.millersoils.co.uk/wp-content/uploads/2022/07/P16104-Classic-Diff-Oil-90.png)
Classic Differential Oil EP 90 GL5
![www.millersoils.co.uk](https://www.millersoils.co.uk/wp-content/themes/millers-oils/images/favicon.png)
I hope this helps,
Rich
