Gear box oil
- Thread starter Eldavo
ikillcopiers
Be careful with that now, I remember a mate of mine had a 205 rally car who held up his car with 4 axle stands, up until an unfortunate day last year. We were swapping heads on some engines (outside of the car, thank christ), and a cat jumped down out of a window in the shed on to the car. Bam! I'd be afraid of even sneezing under a car supported by only axle stands after seeing that happen! But let me tell you, a frightened cat can fairly bolt!ORIGINAL: Eldavo I guess you could support the car on 4 axle stands and this would keep the car level whilst giving enough clearance.
That is a very scary story. I was under the impression that this was the supposed to be the way to do things. In fact I was going to do this whilst Wax Oiling the underside. Guess I will think again.ORIGINAL: ikillcopiersBe careful with that now, I remember a mate of mine had a 205 rally car who held up his car with 4 axle stands, up until an unfortunate day last year. We were swapping heads on some engines (outside of the car, thank christ), and a cat jumped down out of a window in the shed on to the car. Bam! I'd be afraid of even sneezing under a car supported by only axle stands after seeing that happen! But let me tell you, a frightened cat can fairly bolt!ORIGINAL: Eldavo I guess you could support the car on 4 axle stands and this would keep the car level whilst giving enough clearance.
Here's the question, is it physically possible to get under there whilst the car is on the ground? If not I guess it needs to be up on a ramp to keep it flat.
ChasR
edh
Diver944
TTM
Well-known member
A cat? Are you sure it wasn't a pair of Lions instead? I have spent tens of hours under a 944 supported on 4 axle stands and as long as they are located at the right spots the car won't move, even if there is no engine in it.ORIGINAL: ikillcopiers Be careful with that now, I remember a mate of mine had a 205 rally car who held up his car with 4 axle stands, up until an unfortunate day last year. We were swapping heads on some engines (outside of the car, thank christ), and a cat jumped down out of a window in the shed on to the car.
ikillcopiers
Hey, I can only say what I saw. To be fair I didn't put the car on axle stands, that was my mates "job", so I can't say how good or bad it was done. (Maybe we can just assume he did a bad job???) Don't know what else to say? Maybe the puddy cat had a big dinner that day?? Sufficed to say, I'm taking the experience as a life lesson. As with welding a petrol tank, mistakes like that only happen once in a lifetime [ORIGINAL: TTM A cat? Are you sure it wasn't a pair of Lions instead? I have spent tens of hours under a 944 supported on 4 axle stands and as long as they are located at the right spots the car won't move, even if there is no engine in it.
Wasn't this cat was it?ORIGINAL: ikillcopiers Maybe the puddy cat had a big dinner that day??
![IMG_0032.jpg](http://i76.photobucket.com/albums/j14/zcacogp/IMG_0032.jpg)
ikillcopiers
