Been taking advantage of the time off to do some Porsche jobs. Rear brake lines all done... the old ones literally crumbled to bits in my hands. [
While it's up high axle stands I thought I would fit the shiny new short shift linkage from only944. After much swearing I've got all the bolts undone, but the lever that bolts to the selector shaft is stuck solid. Tried WD40 and putting a puller on it, no joy. I'm resigned to drop the gearbox so I can get access to cut it off (will also make fitting the rest of it much easier). I didn't want to put too much force on it in case it shears off something inside the gearbox.
Any tips/tricks before the gearbox comes out??
