scam75
Well-known member
Hi Guys
Bit of a problem developed with the car tonight. I noticed that it was getting a bit stiff to put into gear with the engine running. Switched it off and the gear change is absolutely fine. Started it up again and within a couple of miles it became impossible to select a gear with the engine running.
Once again, with it switched off, selection isn't a problem. I was able to get it up the driveway by switching the engine off to get into reverse and starting up with the clutch depressed.
I checked the clutch fluid and the reservoir is full.
Could it be master or slave cylinder maybe or something worse?
Thanks in advance
Stuart
Thanks in advance
Stuart
