mcgc0
Seems to be my week of minor challenges.. For no apparent reason and with no degradation signs I am unable to select 1st, 2nd or reverse gears. Without the engine on I can select the gears - although a little tight. When on the move (having moved off in 3rd) it can be done but it's bloody difficult.
My clutch biting point seems like less than an inch from the floor. Only thing that has been done in that area is me removing the pedal board to teflon spray the nylon clutch bush that was squeaking every time the pedal was depressed. This was done the week previous and the car changed gear fine after an hour's traffic driving. However, in drawing a template of the pedal board (Al replacement sometime in the future) I removed the pedal stop attached to the board but carefully replaced it in it's same position.
The only thing I can think of is maybe this slipped a tad, but if this was out of adjustment wouldn't it affect any gear selection? I will check the stop anyway and try to measure the the pedal travel to the spec (145mm +10).
Need to ask too about the clutch fluid top-up to make sure this isn't the problem; With a C4 (1990), and the larger shared reservoir with the brake fluid, I noticed the level barely above the Min marker (after following the correct engine start, pump brake, allow for pump to stop running, check fluid level, procedure). Would just this small amount of level change affect the clutch, and then again just for the low-end gear selection? I will need to top up the fluid I guess and hoping I can use any DOT4 plus (but not 5) from, say Halfords or does it have to be something from Porsheshop?
Should mention a new RS clutch and flywheel were fitted back end of 2008 at RPM Tecknik so don't suspect actual clutch issues..
