jboult
I have an ongoing problem with gear selection on a '97 C2 Targa and I was hoping someone on here might be able to point me in the right direction.
When block changing down from (say) 4th to 2nd, most of the time the change is fine, but occasionally (and worryingly becoming more frequently), the gear stick won't move across the neutral plane to 2nd or 1st. It almost seems like it hits an obstruction. Sometimes I can bang it across a couple of times and it will eventually allow me to go far enough to select the gear, other times I need to select 3rd, release the clutch, then change down normally, and everything is fine.
Has anyone got any clue as to what's happening? My local independent said they'd never seen this kind of problem before, so if I can get some pointers as to where to start looking it could save some time and money! Thanks in advance for any help.
Cheers/John
Cheers/John
