I know a few of you guys have fitted new gear shift bushes so I could do with a little of you help.
I have removed the gear shift, rubber boot and main cuttle pin that is held in by the clip on each end, I now believe I have to remove the square shaped box section part that the gear lever goes through before slotting into the bush as this is in the way.
I have punched out the cuttle type pin by the hand brake end of this unit and am now looking at the other retaining pin at the front of this part, it appears to be held in by a large nut with a allen screw going through the middle of it, do I remove this or not as it appears absolutely solid, is it a normal or left hand thread ?.
I also received 2 black nylon bush type things that am not to sure where these go, any help with the above would be much appreciated, sorry if it sounds a little confuseing.
Cheers Barrie
Cheers Barrie
