help please! 1999 boxster tip, when selecting drive d light flashes and box operates fully but in limp mode, if you select tip mode, the lights dont switch over, but when in the tip mode if you push the selector lever forward then backwards with some light force it then selects into tip mode and operates fully, even if you move back into drive the light stays solid and the auto mode acts perfectly. But! if you drop it into neutral then back into drive the drive light flashes once again? im assuming its the selection position switch thats at fault but dont know where its located or could it be cable adjustment?. any ideas or suggestions are welcomed ! thanks.
