DavidL
My gearbox has developed a bit of a whine of late. I had the g/b oil cooler replaced with one from Augment about this time last year (you can't really get OEM ones now) and just prior the whine started. It hasn't really got worse but its very annoying. Obviously it had new oil (swepco) then. I imagine having done 250K+ miles it's just a bit worn and if the box oil level dropped I don't imagine that helped either.
So what are my options regarding rebuilding or replacing the box? It does have the LSD option which I wouldn't want to loose but do these wear?
The only LSD box on ebay is £1k and off a 220 - does it make a difference, ratios different etc?
Thanks - its a 1990 250 turbo SE
David
David
