Gearbox / LSD Oil
- Thread starter RSGulp
ORIGINAL: Damen
Rich
Castrol SAF XJ 70 - 140 is what you need. You can only buy it by the litre (you'll need 4 but the box will take about 3.75 litres) and it's expensive (about £17.50 a litre). Anything else is, in my opinion, a compromise.
Damen
Thanks for the fast response Damen.
Opie Oils have Castrol SAF-XJ 75w-140 fully synthetic final drive lubricant at £12.91 per litre - or £61.34 for a pack of 5. Is this the same stuff?
http://www.opieoils.co.uk/p-736-castrol-saf-xj-75w-140-fully-synthetic-final-drive-lubricant.aspx
They also have a 30% off offer which ends midnight on 18th May (tomorrow) which makes it £57.85 FOR 5X LITRES INCLUDING DELIVERY.
...so if anyone else has any recommendations please be quick... [
Also are the gearbox and LSD separate units or do they share the same drain/fill plugs?
bernard tester
Castrol SAF XJ 70 - 140 great oil but why this particularly? The factory didn't use synthetic transmission oil in the cars, is there a tech bulletin or something that gives the reasons? I know different oils result in different noise levels but I'm not sure that's relevant in an RS! Synthetic oils were said to cause increased wear in pre G50 boxes (which may or may not be relevant!) - Have seen this recommended before and would just like to get the full story!
Tony
Castrol SAF is really a dedicated LSD oil whereas the Silkolene is a higher grade LSD Gearbox Oil which is optimised for combination synchromesh + LSD gearboxes. He therefore recommended the Silkolene over the Castrol.
A very knowledgeable guy to talk to who sounds like he knows what he's talking about when it comes to high performance oils.
Thanks for all the help. The 964RS Gruppe deliver once again. [
When I got my RS a few years ago, I did a lot of research in to this. The factory, Porsche GB and JZ Machtech all stated that Castrol SAF XJ 75-140 was the way to go. When I got the RS it needed a gearbox rebuild but there have been no problems since and all the time I've used Castrol. I change the oil twice a year in the RS and Cup, regardless of how much mileage I've done. Maybe over the top but absolute peace of mind. Both cars have great changes as a result.
Damen
