Hi ,
I`ve finally bit the bullet and removed the engine / gearbox of my carrera to renew the clutch last night.
All was going well untill i tried to split the engine /box. Its a G50 box and it has had the conversion done on the shaft that holds the release bearing ( needle bearings in place of the brass bush) the problem i have is that when trying to remove the shaft with a slide hammer the 6mm bolt has sheered in the shaft !!! Because of the position of the shaft i can`t drill the bolt out now!!
Anyone had this happen or am i VERY unlucky?
Any advice very welcome
Matt P
Matt P
