Gearbox oil change
- Thread starter Guest
Diver944
There are two holes plugged with hex bolts on the exhaust side of the gearbox - a filler hole at the top and an empty hole at the bottom.
Before you start it is very important that you make sure you can undo the filler hole first ! It' s extremely frustrating to drain all the oil from the empty hole only to find that the filler has seized [
Once empty, put the drain plug back in, then pour oil in through the filler until it just starts to dribble out. Replace the filler plug then go have a beer [
Many members of the 944 register have used and recommended Swepco gear oil as supplied by Bert Gear at Berlyn Services - see his ad in Porsche Post
