I dont know if anyone can help but my Boxster S 2001 has just been in for a gearbox rebuild. Well i say just it went in to a local specialist to me in Rushden Northants because the second gear synchro had gone and it was crunching going into gear and jumping out it if you were not firm with the gear change (ontly on second gear). The car went in in April and i`ve just got it back. The gearbox was removed and sent to a gearbox specialist for the rebuild four times its been back in the car and had to come out again as its still jumping out of second if your not firm putting it in. The gearbox co. have now said there is nothing they can do and its not a problem inside the box. My gagage co. have changed the gear selection cables?
Is there anything at the gearstick end that might help with gear selection. For some reason its worse when its cold, once warmed up its not too bad. I thought there might be a nylon bush at the bottom of the gear stick or something?????
