steyning
A 924 (not s-type, non-turbo) for sale has a gearbox that needs replacement. The seller suggests it currently has the 5 speed version, from a 924 Turbo for some reason, with dogleg shift pattern and 016/Z transmission, with cluster behind the differential.
Would it be possible to fit instead a 4, or 5 speed box (016/9 transmission), with conventional shift pattern, which are more readily sourced second hand?
Are they a straight swap / more complicated / just impossible !? THANKS
