Chaps,
'Nother problem with my beloved S2. Crossing over 200,000 miles a couple of months ago has brought all the maladies out at once it seems. The last four times I took it out it has broken in some way or another (starter solenoid, gearchange linkage (outside the gearbox), passenger window coming off the runners, something else (can't remember what)).
The latest is that it is making a 'clonk' noise when changing gear. It's noticeable from within the car and sounds heavy (as opposed to a light 'tap') but isn't a very big noise. I am fairly sure it's associated with the changing of gear as opposed to the depressing of the clutch or the releasing of the clutch. It is associated with changing along the box (i.e. 3rd to 4th) as well as across the box (2nd to 3rd). It very occasionally seems to do it when going over a bump but this could be other noises.
I don't think it is CV's; I had a look at them and one of them had a split boot so I replaced it this afternoon, and the noise is still there.
I haven't yet checked (or changed) the gearbox oil but will do this as soon as I get some (probably in the next day or so). However it was done in the last 3 years or so.
Does anyone have any ideas, inspiration or wisdom to offer? I'm inclined to wonder whether it is something to do with the gear selectors but I don't know if they are even capable of being noisy. The box is not overly loud in other respects and the feel of the change is fine, but it does have a smidge over 200,000 on it now. The other possibility is the gearbox mount and I have read the thread about filling it with goo with interest and may well have a go at this sometime soon.
All suggestions welcome, thanks.
