My "new" 993 is settling into its new life quite well, with just a few niggles to resolve.
One thing I've noticed though is that, when changing out of a gear with the clutch fully down and the engine idling (and doing more than about 20mph), the gearlever is quite reluctant to come out of the gear position it's in and into the neutral plane. However, if some revs are applied (as would normally be the case anyway for rev-matching purposes) the lever slips easily out of gear with only "normal" pressure.
This seems to happen with all gears from second to sixth, so it can't be wear on a particular gear cluster. The gearbox oil has been changed very recently with the correct specification oil.
My question is this: is this normal or not? And if not, does anybody know what might cause it and whether this is indicative of bigger problems in the future?
regards
Nick
regards
Nick
